Discuss Water tank pump housing cracked in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Aaron Bejan
Hey all!
Our water tank pump has been turning off and on by itself and not switching on when needed.
Upon investigation, there appears to be a small crack in the water pump metal housing that is leaking a tiny stream of water.
Would this cause the pump to keep malfunctioning?
If so, are there any solutions to fixing the issue?
Thanks everyone!
Reply to Water tank pump housing cracked in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
