Discuss WB 18ri fan running when no call for heat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stoney Ground
Stoney Ground
Got above where when heating switches off boiler is getting a feed from somewhere, causing clicking noise as it tries to go through start sequence. Where would it get it from, through cylinder Stat or 3 port.
Going there tomorrow to check it out but wanted to grab a replacement just in case.
Probably the end switch in 3 port????
There is a capacitor suppressor that you can fit between N & SwL at the PCB If it is a back feed from a 3ort
Where can I get these, is it something WB know about. Will speak to their technical tomorrow
I work for a company mate,that’s where I heard about this.Quick google search an they are readily available from local places. What did WB tech say?
Reply to WB 18ri fan running when no call for heat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
