Discuss WC runs after flushing — identification of flush mechanism and repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My WC has just developed a problem.
It flushes OK but then the water keeps draining into the pan.
The cistern is a concealed/built-in one.
I lifted the cistern lid expecting to find a siphon but the arrangement is quite different.
I would find it really helpful if someone could identify:
1) the arrangement and manufacturer,
2) explain what the cause of the problem is, and finally
3) what I can do to remedy the situation.
Please see the attached images.
Thanking you in anticipation for your guidance and help.
Thinking grohe or geberit flush? You can pop the flush out and take it to a merchants. It could be scaled it could have a worn washer
Thank you both for your advice. Armed with your information I've found a guide on YouTube about replacing the 'plunger'. Couldn't have done this without your advice. Once again thank you.
I've tried 'popping the flush out' but can't do it. It seems to be firming held in place by a 'overhead gantry'. This seems very firmly fixed in place. I don't want to force anything in case I break something and end up in a real mess. Any advice?
Have to take your brave pills I'm afraid! The gantry lifts off upwards, as you've discovered it can be quite stiff after several years and a bit of limescale.
If you can 'flex' the cistern a little to break free any scale, that can help. I have tapped upwards from below with a length of 2x1 batten in the past - keep it flat to the cradle to avoid uneven pressure which is more likely to break off a lug.
Don't worry too much - it is stronger than it looks (it is also available as a spare part if the worst should happen - I have never broken one yet though)
Reply to WC runs after flushing — identification of flush mechanism and repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I wonder if anyone is able to help with advice on this. We have fitted a new toilet and 6 litre cistern .. it flushes .. but not as efficiently as...
2K
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Had to take the lid off to replace the inlet diaphram, but now can't replace the lid without also messing up the two button mechanism. This is...
3K
I have a high level cistern and was replacing the toilet pan (waste ceramic completely cracked through) and was hoovering around before connecting...
3K
Cast_Iron_Cisterns 486
C
