Discuss Weather comp (baxi ifos) with nest opentherm thermostst in the Central Heating Forum area at PlumbersForums.net
Hi all,
I have just bought a google nest 3rd gen thermostat to be connected opentherm. I currently have the baxi ifos rather comp fitted. I was told that it was either one or the other, but baxi technical dept have said I can wire an opentherm controller alongside the ifos system. Boiler is the main eco compact 30kw combi. Is it better to do this or just use opentherm ?? I have attached the email that I received.
Thanks all
No you can’t your best fitting the nest on the 240v side eg on / off controls and let the ifos weather comp work it’s magic
Reply to Weather comp (baxi ifos) with nest opentherm thermostst in the Central Heating Forum area at PlumbersForums.net
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
Hi all I have a main eco compact 30kw combi boiler installed. This is using weather compensation (baxi ifos) and salus iT500 controller. The...
I've got a Baxi 600 combi, with a Google Nest thermostat, fitted a year ago. I've just learnt about OpenTherm, so went into my Nest settings, and...
Hello everyone, I am new to the forum, thanks for having me. Tomorrow I am getting an ATAG i28C installed but, unfortunately, the gas engineer...
2K
Hi all Had my old baxi 105 replaced with a baxi 630. Got the ifos fitted and set to curve 40. So far all ok. My controls are a salus iT500. Now...
