Discuss Weird Hive issue with scheduling in the DIY Plumbing Forum area at PlumbersForums.net
Hi guys
Weird one this, when boiler is firing and heating water if my scheduled rad heating come on also it doesn't heat my rads...
BUT here's the weird part if I BOOST the heating the at same time scheduled water is on then it works?
Possibly wired wrong then or faulty valve. Is it mid position type which model of valve as said photos of set up would be ideal
Thanks bud for your input... To be fair it's been in place years, without any issues with my hive set up.
Yes I will get a picture uploaded, does sound like a valve issue doesn't it.
Trouble is BG take about 3 visits and 3 different engineers to get it diagnosed.
Reply to Weird Hive issue with scheduling in the DIY Plumbing Forum area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
J
Morning all, My Vallient Ecotec Plus 831 is stored in the loft and is connected to Hive. It is coming on randomly at various times of the day, but...
J Hughes
J
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
As above new boiler fitted and new Hive, Hive is set up correctly and works as it should but when it comes to scheduling on/off times via Hive the...
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower...
