Discuss Well pump running but no water? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
K
Kevin L
So for the past month or so I’ve been intermittently losing water to my house, each time this has happened I’ve been able to manually reset the well pump pressure switch and the pump would turn on and start pumping water. I thought I just needed a new pressure switch, no big deal..
This morning I had to reset the pressure switch once again and the pump turned on but it’s running dry and not pumping any water to the house, so it seems now I have another problem. I doubt the well is dry because I live just next to a lake and we’ve had a lot of rain recently so there should be plenty of ground water. What else can I check?
Reply to Well pump running but no water? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
