Discuss Wet UFH: low profile vs screeded in the Water Underfloor Heating Advice area at PlumbersForums.net
What are the disadvantages of low profile wet UFH boards, in comparison to conventional pipe-in-screed systems (those in which there is at least 50 mm of screed)? Would these disadvantages be as relevant in a small bathroom (wet room) application, for which the total floor area is less than 10 m2?
Not much thermal mass and not much insulation below but they warm up faster
I am planning to insulate either way. If using low profile, vacuum insulated panels.
Is a lack of thermal mass relevant if the UFH is only for a small space, that isn't normally in use? I.e. time it to come on for 1 or 2 hours first thing in the morning?
No would only effect it when it’s off eg cools down quicker
Just wondering if there are any other aspects to be aware of if going for low profile vs traditional screed? Must be reasons why it isn't more popular because at the moment, to me it looks like a get out of jail free card for retrofits.
Exactly......
Smaller diameter pipe and pipe spacings closer.
PITA control in a small area unless you have other areas you can control on the same manifold
Oz-plumber thanks, but I'm not sure if I follow. Excuse my ignorance, aren't you describing just a sizing issue? What do you mean exactly by control, and why would the small bore pipes and small area make it inherently more difficult? I'm not sure I see the need for a room thermostat controlling just the UFH in the bathroom, just have a timer and water temperature set point instead.
Reply to Wet UFH: low profile vs screeded in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi, I have a seaside apartment in Azerbaijan, currently a bare core & shell, not even internal walls yet, and am intending to put in wet UFH with...
Hello all. First time posting so apologies if this is answered elsewhere. I am close to completing a purchase of my first flat, an ex-council...
2K
Hi there, thanks for taking the time to read this. I've been trying to diagnose why my gas consumption is so high and been doing various...
4K
We currently have the ground floor wet UFH and upstairs rads running from an unvented condensing boiler. Any advice/experience on the following...
Good day all, I would like to get some advise and perhaps the solution to the issues with my UFH system. We did install UFH in an entire house...
5K
