Discuss What amount of water pressure comes through a normal house ? in the DIY Plumbing Forum area at PlumbersForums.net
Every time I use a stop end when I turn the water back on I think to my self that’s going to pop off and flood the house. What amount of pressure can they with stand ?
Depends on what type of stop end!
If your referring to push fit speedfit is max 12 bar at 20C as water temperature goes up max pressure comes down.
Reply to What amount of water pressure comes through a normal house ? in the DIY Plumbing Forum area at PlumbersForums.net
PSxxxxxx
