Discuss What are people using to fix lead mains... in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
mutley racers
Subscribed
What products are you using to repair lead mains? Philmac, leadloc or others.
Rod or bar of solder
I'm old enough to have wiped many lead joints mostly to put new stop on.
Solder was grade D turnpin to make flange clamps to hold it together wiping cloth tallow as flux.
Thank goodness now long gone!
Not sure I understand some of this message as parts of it name a user on here from yrs back. Turnpin.
Still got plenty of those in different sizes as well as the clamps, cloths, bent pins, lamps, dummies etc.
All museum pieces now.
Only lead work we do now is stone gutter caulkings and the odd flashing or a pipe repair.
Last time I spoke to a college tutor for Plumbing he told me they don't teach any lead work anymore!!
How can the new guys be Plumbers? 😬😬
Times change!
Times change!
Apparentl, when I sat my NVQ level 3, we were told then that they were no longer teaching lead-work in college, I asked what it was being replaced with, the answer was “renewable technology“.
How does renewable tech replace a lead pipe or lead flashings? Or did they mean new materials?
Fast fit flashing eg pre made unfortunately there’s no point in them teaching it as it would never get used with a combi slinger
Reply to What are people using to fix lead mains... in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
  • Sticky
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
