Discuss What could be causing this? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, would anyone like to hazard a guess at what's causing this problem on the ground floor of our house? As you can see, the bottom of both sides of the door frame are wet. The doorway is nowhere near any windows and is positioned pretty much in the centre of the house. Could this be water dripping down a pipe from above or likely some kind of leak under the floor? Why would it be localised to the door frame?
I've had two plumber/builders visit to give an assessment but both declined to take the job any further. It's very worrying and I just want to get it rectified.
Is it a concrete floors?
If you turn the central heating on does this leak become hot?
Is your water meter constantly spinning even with no usage in the house?
How about if you turn the internal stopcock off?
Etc etc many questions but these 4 will do to start with…
Could be a number of things. Nailed pipe, pin holed pipe, leaking joint. Needs investigating obviously. I'd see it as a challenge and sort it! It can't be that difficult. Its not a bad job is it?
What amazes me is the amount of times (not just on forum but in real life) I hear "Plumbers won't take it on". I've heard it twice in as many weeks and it's not one plumber either, it's normally a procession.
Why would a Plumber not take that on? The two above have engaged the same part of the brain as I did from the off. Curiosity, intrigue, challenge etc. To locate that and fix it gives a sense of job satisfaction never mind being paid.
Maybe it's a generation thing? God knows!
Looking at the circle of damp, my guess would be that there's water running down the inside of the architrave. Or a pipe behind it? What's above? What did the visiting Plumbers think it was?
I have had to repair a couple of leak for floor fitting friend wher the pipes run down behind the architrav. But If floors are wood I would plump for the carpet gripper through pipe.
Reply to What could be causing this? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady upstairs had a plumber in July who relocated her washbasin shower and fitted a new radiator.He caused a bad leak and came to fix it in august and I thought...
My son moved to a new build home in Cornwall last November. Yesterday evening he found a quantity of water beneath the Ideal Combi boiler and a steady water drip from the boiler. After clearing up and putting a container beneath the boiler, he went to bed. This morning the water drip had...
Hoping for some advice as I seem to be hitting a brick wall. Moved into a house last year, radiators down strairs (4 of them) never really got warm, replaced the combi boiler this year as it was loud and leaking (its in the loft which has been converted into a room). Since turning the heating...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current boiler is on an external kitchen wall with the flue going straight out. However, it's positioned in between a door and the kitchen window, quite close...
