Discuss what is a parallel junction? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. On a single stack soil and waste system. it is a method of connecting the bath / shower waste in to the stack. ( Owing to the WC branch being close to the floor, running a waste into the stack at this point is hindered by WC branch, you simply put a bossed pipe in below WC branch normally 2" pipe put on a bend and pipe to point upward, cut at floor level and fit a access branch and connect waste into branch and rodding eye on top. Good luck
thanx justlead, it was for homework. do you get much work on the lead side?
Reply to what is a parallel junction? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
