Discuss What is causing myLeaking showerhead when sprinkler system pump is pumping in the USA area at PlumbersForums.net
Sprinkler system with a 1/2 horse pump works fine for over 25 years, This year as it is pumping to the 4 zones which is working fine with normal pressure, the shower head in my upstairs bath is now leaking water from the head. The water is turned off as normal but the water is coming out of the head as if there is pressure in the line coming from somewhere. What do you think may be causing this showerhead to start having this water coming up and out even though the water is turned off, both hot and cold?
All the other faucets and shower head in the other baths are okay and not leaking, just the one.
Can I please get an answer to this issue and will it cause any other leaks or damage
Thank you Frank
Reply to What is causing myLeaking showerhead when sprinkler system pump is pumping in the USA area at PlumbersForums.net
