Discuss What is the best setting to keep the central heating coming on daily when I'm away? in the Central Heating Forum area at PlumbersForums.net
Gee
Hi, I have some questions about setting the thermostats and would appreciate some help. I would just set the programmer to twice a day but I'm concerned about power outages which we get a lot of so would like some advice.
  1. If I set the thermostat for the pipes (numbers on dial start at 3 and end at 10) at 10 and the thermostat on the boiler (worcester bosch) to antifreeze, will the central heating come on when the pipes-thermostat senses that the temperature is 10 deg c? Or will the thermostat on the boiler counteract it and turn on the heating only when it gets closer to freezing temperature?
  2. Will it work when the timer/programmer is set to 'off'?
  3. What temperature will the water get heated up to?
  4. Will it also heat the water in the water tanks in the loft?
  5. How do I ensure the heating comes on when it needs to even after a power outage?
Thanks for reading.
Kind regards
gee
Reply to What is the best setting to keep the central heating coming on daily when I'm away? in the Central Heating Forum area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
M
I've got a heating boiler which heats up the water in a tank located in a cupboard upstairs and then from there I get hot water & hearing. I get...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am...
