- Messages
- 5
I need to fit a valve into my sink feed and space is tight. Just enough to get a tool in to release them later. Thanks.
Discuss What is the minimum distance between Speedfit connectors? in the USA area at PlumbersForums.net
Not worth it for a quid or 2 fittingI also found I could reuse an elbow even though I had to drag a corroded copper pipe from it - impressed!
Bit more than a quid though. If there are four to change could save me twelve quid! Reuse, Reuse, Reuse is my aim. Dont know if you can recycle these connectors. Probably not!Not worth it for a quid or 2 fitting
But if you get a leak no problem.Bit more than a quid though. If there are four to change could save me twelve quid! Reuse, Reuse, Reuse is my aim. Dont know if you can recycle these connectors. Probably not!
Unless its a genuine "Miss Popoff" which happens while youre on holiday.But if you get a leak no problem.
Reply to What is the minimum distance between Speedfit connectors? in the USA area at PlumbersForums.net
