Discuss What is the UK version of this fitting called? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MarkR
Hi Again,
I'm still looking at different fittings. Can anyone tell me what the UK version of this is called?
ebay.com/itm/New-Old-Stock-1-2-x-1-2-BRASS-in-line-Coupling-Solder-Sweat-with-Bleeder/182075601265?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36469%26meid%3Df37e7179215e4c30b9037d922f4bf515%26pid%3D100011%26rk%3D1%26rkt%3D2%26sd%3D182041479013
Do they exist in the UK and if so what would a plumber's merchant call it (as I'm assuming the DIY stores won't stock them)?
(I hear Chris saying 'we never use them' again like on my last question :vanish:)
Best,
Mark
P.S. Seems like my low post count doesn't allow links
You are a determined little bugger Mark I will give you that. :wings:
I guarantee you will not use one of these when you find out how much they cost / difficult to get hold of.
I can't use your link but from memory you were after a Cross tee Yorkshire did one code is a YP50 followed by 08660 for 15mm, 08661 for 22mm or 08662 for 28mm.
Compression it would be a K623 from the 600 range.
Hope that helps
Hi Chris,
I took the advice before about the cross tee - I'll use normal tees. I'm now looking at a different fitting. Sorry the link doesn't work (doesn't allow me to post with a working URL). Will try to attach a photo.
I would describe it as a 15mm straight solder (not compression) coupling but with a small bleed valve.
Best,
Mark
(Arrggg... can't post a local image nor link to one! "Post denied. New posts are limited by number of URLs it may contain and checked if it doesn't contain forbidden words.")
Well, I've been a plumbers merchant in the UK for 30 years, and I would have denied that they existed if it were not for the evidence to the contrary.
I would be gobsmacked if you found any merchant with one on the shelf. Any merchant daft enough to carry that on the shelf would have gone bust years ago. Why would you want one, when you could make up the equivalent out of fittings for a tenth of the cost?
Google "1/2 brass coupling sweat bleed" and it's about the first picture.
Got link to work air vent tee "we don't use them any more" try Page 5 again an RV35 Air Release Valve which can be soldered into any tee with a 15mm connection (don't forget to remove the cap before soldering & replace after wards).
Of course you could alter your designs so you could incorporate a YP35 then you wouldn't have to solder it. LOL
Thanks Shaun for sorting the link - that's the fitting.
This looks cheaper...
NoLinkingToThis/p/end-feed-air-vent-cap-15mm/52451
(doesn't allow me to post links!!!)
I assume that can be soldered to any tee with a stub of pipe.
Reply to What is the UK version of this fitting called? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
