Discuss What is this Lp fitting called? in the DIY Plumbing Forum area at PlumbersForums.net
When I disconnected my natural gas cooktop this part was split in two. I have been to big box hardware store and they don't know what it is. Any help naming it and where can I get one. See part and the cooktop attachment.
Thanks for any help!
Tracpipe will need to go to proper plumbing suppliers for fittings that part is meant to be split,
you need a registered gas fitter to work on this.
Can’t you undo the existing one out of your original one and put it into your new one ?
If your on about the brass collar it’s supposed to be two parts
Reply to What is this Lp fitting called? in the DIY Plumbing Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
