Discuss What is this shower fitting called in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
The plastic connector/convertor which the shower hose attaches to has been leaking and needs replaced.
Beneath a cover is a screw which attaches the plastic unit to the protruding fitting.
Can somebody please tell me what this fitting is called and ideally point me in the direction of a replacement plastic part.
Thanks.
The silver outlet unit which has the shower hose fitting on it, is pushed on to the brass fitting, and there is a cover which is screwed off which hides the screw which fixes the silver unit to the brass piping.
The water doesn't exit the end of the pipe, but instead is diverted up and down between the two circular parts which have rubber seals round them.
They fit into a short tube on the inside of the silver outlet which then diverts/leads the water to the threaded hose outlet.
I am not a plumber, which you will have guessed by now, so I don't know what the correct terms are, but having searched Google using obvious terms this seems to be an unusual, if not unique, way of getting water from the mixer to the shower hose.
Has anybody seen anything like this before.
It will be specific to that shower range or manufacturer. If you can identify the shower then you stand a chance of finding the part.
Or you could replace the o rings and some silicone grease.
Reply to What is this shower fitting called in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Sonya K
