Discuss What is this valve on cold feed in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, can you tell me what this valve is on the mains cold water feed and is it necessary to have thank you.
Non return valve what’s the appliance?
To protect against back flow as it’s a drinking fountain
It’s a verifiable double check
Thank you for the replies and useful information it is much appreciated.
Next question is, where should the double check valve be fitted, on the cold-water feed pipe before or after the stopcock under the sink which would be 15mm in size or on the incoming mains pipe which has a T bar on it and is 22mm in size? Thank you
In flats, they sometimes put a check valve on the incoming supply pipe to each flat to stop upstairs water running back down to lower floors if the mains supply fails or is shut off.
But this kind of valve could be fitted for many reasons. Most commonly to stop backflow from a specific tap or appliance such as a washing machine. So the correct place to put it depends on why it was put there in the first place.
It is very rare for a check valve to be a problem even if it proved that it were fitted somewhere it is no longer needed.
Reply to What is this valve on cold feed in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
