Discuss What size pipe insulations fits over 42mm compression fittings? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MOSSEP
All in the title really, What size pipe insulations fits over 42mm compression fittings?
I don't have one at hand but need to place an order for some pipe insulation. Im thinking 54mm but not sure.
Cheers!
Reply to What size pipe insulations fits over 42mm compression fittings? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
