Discuss What to do with my Central Heating pipes in this scenario? *Help*! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. This is part of a narrow L-section of an upstairs bathroom in a house I'm renovating. The toilet sits here.
I forgot to take a pic whilst up there, so I've drawn a diagram.
Black = walls
Brown = joists
Blue = CH pipes (hopefully) - they're already notched in this location but unused.
I need to run some CH pipes for a radiator immediately below on the ground floor (has a concrete slab so must run under upstairs floorboards). I want the pipes buried in the walls. No trunking or boxing.
1) If I want to put the rad on wall 2 - I must chase out that wall right behind the joist, and it's almost flush with the wall. Possible?
2) I can def route to wall 1 and put the rad here. But, it'll cost 3x the amount for the 28mm wide designer rad to fit behind the front door.
3) Can def route to wall 3 below, but there's a switch and socket on that wall and it would face the front door and is in a narrow porch area.
Please advise!
Cheers,
David
How close is the timber on wall 2 is it tight or is there a bit of room ?
It can be done just need to chase a bit more out behind the timber
Reply to What to do with my Central Heating pipes in this scenario? *Help*! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
