Discuss What Type of Services need to expect from a Commercial Plumber? in the USA area at PlumbersForums.net
Professional service?
Silly question: Does your project also have any elements of masonry, carpentry, electrics etc etc. Does it need a surveyor first? Does it need building control?
Many professional plumbers are multi talented, but be careful to think clearly about this.
Can you explain a bit more about your project, and perhaps add some photos of relevant.
Cheers,
Roy (amateur)
Reply to What Type of Services need to expect from a Commercial Plumber? in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
