Discuss What's the nut on top of a gas supply bayonet fixing used for? in the Oil and Solid Fuel Forum area at PlumbersForums.net
I have a redundant gas cooker supply to cap, but wondered what the nut on the top of the gas supply bayonet fitting is used for?
Picture ?
Presumably to allow the valve components to be assembled inside (during manufacture) šŸ¤”
If you're talking about this sort of thing:
I expect it will be how they assembled the fitting.
In theory they are designed to be disconnected and gas tight. Realistically though I would get it capped. IT IS NOT SOMETHING A NON GAS SAFE ENGINEER CAN DO.
Guidance Note 65 to regulation 6(3) of GSIUR states:
ā€œWhen an appliance is disconnected and open-ended pipework is left, the pipework should always be left sealed with an appropriate fitting. A self-sealing coupling, e.g. on a cooker connection, does not need to be capped-off, except where there is a significant risk of interference (such as by a child). However, it should be checked that any disconnected coupling is not leaking gas (see paragraph 68), and any wall- mounted connector has been installed in the downward mounted position to prevent dirt or grit getting into the self-closing seal.ā€
Reply to What's the nut on top of a gas supply bayonet fixing used for? in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
