- Messages
- 2,015
Discuss What's Yellow? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had that with me mate but tbh all the wires just confused me. I reckon I could have worked it all out if there was one cable in there that was just blue brown and green/yellow as I assume that would be the boiler but there wasn't anything like that? Was well beyond me tbh so recommended a sparky. Need to get on the Honeywell Wiring course sharpish!Have a look through here, you can then trace each wire off the valve which should tell you what each wire on the other side of the connector block is doing
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&sqi=2&ved=0CEUQFjAA&url=http%3A%2F%2Fwww.honeywelluk.com%2FDocuments%2FFull-Install%2Fpdf%2F1083.pdf&ei=F9AbUfvnH-Sa0QXs4YDQBA&usg=AFQjCNGpxW7HHIfSo_cTt284EEwRQHn5Hw&sig2=Abv_FacGed6pE8JLKYTw0w&bvm=bv.42261806,d.d2k
The bloke who owns the house was a sparky so to him was probably piece off piddleThe only wires you can be sure of are the earths and if all blues go together they are probably neutrals. Everything else is in the head of the guy who wired it (probably a spark) and are just switch wires.
Easy enough to follow if you think about it.
Starting from the bottom.
1. Hw on from cyl stat, pump and boiler switch lives and the orange to the valve
2. Hw off from clock, hw sat from cyl stat and grey to valve.
3. Heating on from room stat and white on valve
4. Probably boiler switch live linking to 1
5. Possibly a permanent live.
Neutrals and earths are below the other connectors.
Test them to confirm.
Reply to What's Yellow? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
