Discuss Where can I obtain a used American Standard bathroom faucets? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
T
tmarsh2BU
Our 3/8" compression hose connecting cold water shut off valve to faucet handle (older American Standard Kirkdale widespread set / now called Edgemere line) ruptured. Unfortunately, American Standard doesn't seem the compression hose separately or with the handle kit. The hose appears non-standard. While then size (3/8"), length (24"), and female end (threaded with nut) are standard, the male end isn't. It looks like an m10 with two o-rings but it's not threaded.
Any idea where I can obtain a replacement hose, new or used? I'd rather not spend $200 for a whole new fixture if I can avoid it.
We're currently located just northeast if San Antonio, TX.
Reply to Where can I obtain a used American Standard bathroom faucets? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
