Where is the water coming from?? Hot water tank keeps dripping....
View the thread, titled "Where is the water coming from?? Hot water tank keeps dripping...." which is posted in Central Heating Forum on UK Plumbers Forums.
DuncanP
Hi all - hoping someone knowledgeable can help as I'm super confused by this....
I have a standard system / gravity fed boiler, large cold tank in attic, hot water tank in airing cupboard etc. I recently found that the hot water coupling into my shower pump (salamander) had sheared (the plastic 90 degree elbow on the anti-vibration coupling). Anyway, fine, ordered some new anti vibration couplings and shut off the isolation valves (all 4) on the pump while i wait for them to turn up. I also turned off the cold water inflow to the hot water tank so I can keep the cold water on while I replace the couplings. All fine I thought, I'll just drain the hot water in the pipework and wait for the replacement parts. However, when I turn on a hot water tap, after an initial surge while the water in the pipes clear, the water from the hot water tank keeps dripping - granted slowly, but enough to fill up a large saucepan every 3-4 hours. Not a big issue, but seems strange - where is the water coming from??? Any ideas? Do shut off valves normally leak a bit? Could there be any backflow from the cold water system? Could the heating loop inside the tank be leaking into the tank?
Many thanks,
DP
Hello Duncan.
Yes a shut off valve can pass, they’re not supposed to but can. It could be that it’s not shutting off properly anyway.Could be backflow/crossover and this would need to be confirmed.
Reply to the thread, titled "Where is the water coming from?? Hot water tank keeps dripping...." which is posted in Central Heating Forum on Plumbers Forums.
DuncanP,
Deleted member 120897,
