Discuss Where is the water going? (Leak) in the USA area at PlumbersForums.net
Bit of a long video here, but I'm really hoping someone can help. We clearly need to get someone in to fix the leak, but meanwhile I'm concerned where all the water is going to.
There is no water damage in the surrounding area. Walls and floor seem perfectly fine.
I can't work out where the water is running to. Any thoughts?
It's soaking into the floor, if it's concrete and if there's a room below, eventually it will show through on the ceiling.
If it's a timber and wood floor with a room below you'll see it when it breaks through the ceiling eventually.
Reply to Where is the water going? (Leak) in the USA area at PlumbersForums.net
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
A while ago I replaced a leaky, corroded sink trap. That all appears to be fine, I can't find any leaks with it, and everything under the sink...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
