Discuss Where to buy oversize tray waste in the The Welcome Wagon :) area at PlumbersForums.net
Hi all, Just purchased a new low profile 1400 x 900 shower tray but the waste hole is 160mm wide, never seen one that big before but are these available to buy. Think my tray is a cooke & lewis eclipse, see attached image.. Hope someone can advise me on where to purchase a tray waste. Thanks..
As above the waste should have come with the tray. There are ads on the interweb showing the complete shower, glass, waste, etc with that tray, as it was originally all sold as a complete kit.
Was on sale a few years ago, and all the reviews if you follow the link in the above are from France and not very good!
B&Q themselves don't carry it any more
If you bought it through B&Q, Amazon, or another agent, I would send it back 🤔
With something like a shower tray that gets fitted then tiled over then a screen on it, If you then have difficulties you're looking at a lot of money to have it put right. The tray you should buy should always be a decent quality and time spent installing it properly because its so expensive and time consuming to put right.
I didn't know Cooke and Lewis made shower trays. There taps seem to be the most popular as customers go into screwfix or B&Q and buy one but they are all a load of rubbish. They leak from the O-rings, the cartridges let by or the handles of the taps become incredibly stiff after a short period of time. They have done the absoloute bog standard to sell a product which is disposable and only offer warranty past 1 year on the chrome not the components. While they are cheap its not economic to fit because it is almost guaranteed to be changing it within a year or two.
For £75 I would take it back or write it off. £75 is an absoloute tiny cost compared to £500+ it would cost to remove the tray and fit a different one at a later date if it failed
Any pictures of the actual hole ?
They don't.
It's B&Q's own brand name, they use various suppliers for different products in the range, but badge them all Cooke and Lewis.
The tray will be made by one manufacturer and the waste made by another company specifically for the first if it's a non standard outlet.
This one has a similar sized waste hole by the looks, just smaller dimension tray.
If you look at the middle photo it shows a flange plate as would be used on a vinyl floor, probably as an adapter for a fairly normal 90mm waste
Maybe something like this would work,
Bin the tray that you I’ll be hard to find a waste for
I believe these are the instructions (link at bottom of here) for fitting the oversized waste, note it has MX Group in the title,
Here's their contact details, don't if they are still around but the website looks up to date.
Google maps image is 2011 but company House show Marleton Cross Ltd trading, with a registered office recently (April 2023) changed from the below address to Northampton.
Marleton Cross Limited Trading as The MX Group
Alpha Close
Delta Drive
Tewkesbury Industrial Estate
Tewkesbury
Gloucestershire
GL20 8JF
Telephone: +44 (0)1684 293311
Fax: +44 (0)1684 275125
Helpline 0845 5052211
Email: [email protected]
There was a thread on this forum in 2011 about a very similar or same waste and complaining a leak through the screw holes, so if you do get a waste from MX and use it DON'T drill the tray for the 5 holes, just use silicon to hold the flange in place.
And buy a spare waste in case any part of it fails.
Reply to Where to buy oversize tray waste in the The Welcome Wagon :) area at PlumbersForums.net
I have bought a shower tray and it has an extra large hole for the waste trap. Its a cooke and lewis think its an eclips 1400 x 900 tray. The hole...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Good afternoon, please see my attached diagrams One is the current layout And one is where I propose to add another boss to add a shower waste...
I have a Neo-Angle shower tray, … imagine an oblong with corner cut at 45 degree It’s 1.2m x 0.9m The ‘Roman’ shower door has failed, the only...
