Discuss Which pump? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
I have a shower pump in my loft which recently started to leak and has been taken out by a emergency plumber.
The hot water tank is in the bathroom below, whilst the cold water tank is in the loft with the pump.
The emergency plumber mentioned I needed a special pump that would be able to draw the water up the pump to then out to the shower below.
Is there a special name for this type of pump?
I asked in the plumbers merchants and they said the plumber would tell me what it's called.
Can someone tell me what this type of pump is called??
Forum rules ask that you register to receive replies. Thanks.
As my dear friend has pointed out you need to register and repost. Thanks you.
Reply to Which pump? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi, I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank. Normally the pump would stop working...
Wanted a new shower pump equivalant to a Branston Varispeed 50 After 12 years my shower pump has stopped working and it looks as though this type...
