Discuss Why do i have low pressure? in the USA area at PlumbersForums.net
Why do I have low pressure in my hot water taps? Takes about 30/45 mins to fill up my bath and takes ages for the hot water to come through taps. Had the heat exchanger changed on my boiler last year? Would it be plumbing or boiler related?
Is your cold water the same as make and model of your boiler plz ?
Would you say hot and cold are about the same or not much in it upstairs?
Nothing you can do other than to speak to the water board maybe they can increase it for you
If it takes 30-45 mins to fill the bath, that equates to around 2.5lpm.
Most water suppliers are obligated to supply a minimum of 1 bar and 9lpm at ground level.
I’d measure the flow rate at each outlet and if possible directly after the main stopcock.
You may have a supply issue that the supplier will fix.
You could also look into mains boost pumps.
Reply to Why do i have low pressure? in the USA area at PlumbersForums.net
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Hi I moved into a property where the pressure is slightly low and they have this super duper shower but pressure is somewhat lacking. I have had...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals...
