Discuss Why does my basement toilet backflow? in the USA area at PlumbersForums.net
Hey there,
First time posting here, thanks in advance for any advice you can give. First things first: I'm an idiot and I have no idea about proper plumbing lingo so go easy on me! I'm pretty cash strapped but I have a serious problem with my basement toilet and shower drain - dirty water is bubbling out when 3rd floor toilets are flushed. From what I can tell, all 5 of the toilets in my house drain into the same line. The drain pipes converge in the utility room next to the basement toilet, and go below the concrete slab from there. But the basement toilet sits on the concrete slab, so it has to converge somewhere below the slab. So I'm thinking there is probably a partial clog somewhere below the foundation, and the force of the 2nd-floor flushing toilets is enough to bubble up the basement toilet. On rare occasions we'll even get foul sewage coming up from the basement shower drain, and I just have to use a plunger to get it to re-drain again. Attached is my very crude drawing of my house's toilets.
This started happening last year, though not nearly as bad, and I paid a "plumber" about $550 to snake the drain and put a camera down there. He said he couldn't find any blockages, and went almost all the way to the street with the camera. In my area (Washington DC suburbs), finding a competent plumber who has time for small fixer projects is pretty difficult because they're just too busy with large new construction jobs. The guys I can afford and who's attention I can get seem to have no idea what they're doing. So I'm pretty resigned to having to at least identify the actual problem myself before I call someone.
It is possible that a clogged vent on the roof might cause a basement toilet drain to backflow like mine is? It's a tall roof, and although I have a ladder that'll get me up there I don't want to do that unless it's a strong possibility that it's clogged. Any other ideas I should try? Thanks for reading and any helpful ideas!
Tim
You can hire a cheap plumber or a good plumber, cheap plumbers usually work out more expensive because they aren't able to get the job done. Hire a proper professional. Try and get a recommendation from friends and neighbors.
Sounds like you need a cctv survey of your drains.
Reply to Why does my basement toilet backflow? in the USA area at PlumbersForums.net
Hi, Im a DIY Plumber Im working on moving my plumbing in my basement to the other side of the soon-to-be bathroom. I've busted up the concrete...
My house is on a block foundation. It needs to be dug around outside and resealed. Estimate was over $30k so that is not an option. When the...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hello, I'm reworking our ensuite which is next door to the main bathroom. I want to connect the new toilet into the existing soil pipe which runs...
