Discuss Why Does Vaillant EcoTec 832 Boiler Only Heat in Chimney Sweep Mode? in the Central Heating Forum area at PlumbersForums.net
Hello everyone,
I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice.
The Problem:
  • Heating Not Working Normally. When I turn on the heating, it doesn’t start. However, I still receive hot water, suggesting the boiler does work in some capacity..
What I've Tried:
  • Chimney Sweep Mode: Interestingly, when I activate the 'chimney sweep' setting, the heating does come on.
  • Pressure Check: I’ve had difficulties firing up heating after a long time off before. Usually it's because the pressure has dropped right down. I opened up the filling loop to bring it back up to pressure but it didn't do the trick this time.
  • Resetting the boiler: Attempted a boiler reset to default settings by pressing the button on the front. I also tried turning it off and on again.
I haven’t delved into any complex internal components for safety reasons. Above is pretty much the limit of my skills with this machine. I'm seeking guidance on what might be causing this issue and how I might resolve it or if it’s time to call in a professional.
Thank you in advance for your time and advice!
Port valve probably I’m guessing heat/ system boiler ?
It’s not a summer mode by any chance eg hot water only ?
I had a look for a summer setting but not sure there is one. Heating is turned on with manual switch. No icon displaying summer mode active either
Room stat ?
Could be
Needs a engineer to test ideally
Reply to Why Does Vaillant EcoTec 832 Boiler Only Heat in Chimney Sweep Mode? in the Central Heating Forum area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd...
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating...
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
Hi all I have a Vaillant eco boiler at a new house I moved into last week. It’s a combo boiler and the last boiler I had was old (and much...
