Discuss Wickes monobloc Mixer taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Help needed please. Can anyone enlighten me how to access the cartridge/valve on Wickes Kumai monobloc kitchen sink mixer taps. I have looked everywhere on the taps for an allen type screw to enable me to remove the cartridge/valve cover. The last mixer tap I had there was a allen type screw on the actual cover to the rear. Any help would be very much appreciated.
Thanks for your reply snowhead. I have unscrewed the pegs and taken them off but can’t actually see any retaining screw.
Are you sure there isn't a grub screw with a hex key head on it? They can be quite hard to see if a bit inaccessible. Maybe try a few allen keys in there carefully (as in avoid head stripping if slightly to small a size selected) and see if anything bites.
Just a guess but, Have you tried unscrewing the peg that forms part of the handle.
It's the same tap as BENCHMARX / chantilly 546822 apparently, instructions at bottom of linked page;
https://benchmarx-kitchens.scene7.c...bloc-Sink-Mixer-Chrome~GPID_1010013568_TECH_0
Did you already know that its the same tap as Benchmark one or is there a secret trick to finding this out? Wickes can be particularly crap at putting instructions online for their own brand stuff.
look at snows link pg 2 item no 3 defo a grub screw
First line I posted was a guess.
Then I Googled and found a reference on Ebay, then Googled the Benchmarknumber;
MODERN MONOBLOC KITCHEN SINK MIXER TAP CHROME 360 DEGREE SWIVEL SPOUT DUAL LEVER | eBay
WICKES / Kumai 173898
TP / iflo kisdon 177007
If someone Googles Wickes Kumai in the future, after the Search engine Bots have crawled around, they'll probably end up on this post.
Reply to Wickes monobloc Mixer taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
