Discuss Will new pipework airlock? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
djboyd
Hi
I hope someone can help me out with new central heating pipework I have installed in a new extention - 5 radiators fed by 22mm from existing house stepped down to 15mm for each rad (or two). However, the existing house concrete floor is not level meaning the pipes slope upward to the point where they join the new build, where they then fall slightly to the drain points and rads. The concrete floor has 2" battons then flooring so there is not enough room to offset the floor uneveness (is that a word?!). Is this likely to cause an airlock, it is a standard gravity fed system?
Thanks for any advice.
yes/maybe but do a search on here airlocks are every day occurrences
Basically if it does you can get rid of them with some simple bits of DIY equipment and some patience. Annoying on a job, not so bad in your own home on your own time.
Thanks for the replies - I did try a search, but I thought my airlock situation was unique! Good to know it will not be a major issue, the alternative is to get the sds out and chase a long channel out the concrete. I am thinking it will make sense to branch a radiator off at the high point to take the air to the rad - is this right?
Thanks again
yes it can airlock, if u fit drain off lock shields you can back fill through a hose
Reply to Will new pipework airlock? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
I have a 320 sqft double storey house with 6 bedrooms. The house is serviced by two heat only boilers (non condensing); a 120k btu (35kw) and a...
1K
Hello all. I've just joined, was going to post in the new members forum, but the first site generated email sent me here... I am here, as have a...
3K
I'm trying to get to grips with a system I have inherited as a new home owner. I know that single pipe systems are crap and should be replaced...
2K
Hi folks, I’m in need of some sound advice. We have recently had a ground floor extension and have had underfloor heating (company: JK UFH)...
4K
