Discuss Will Standard Pipe Clips Make Pipes Stand Far Enough Of Wall To Fit Pump Valves? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just changed the plate hex on my Turbomax due to lots of rust flakes inside(despite corrosion inhibitor) causing poor hw performance. I need to flush the system and fit a filter. Because of system design, the only 22mm pipes that are accessible are on standard plastic pipe clips on a wall nearthe boiler. I want to fit a Boiler Buddy, which will entail fitting pump valveson the return .
Will the standard pipe clips give enough clearance of the wallto fit the valves and BB, or will I need pipework alterations?
Many thanks for any advice.
https://www.plumbnation.co.uk/site/fernox-boiler-buddy-magnetic-filter/
Fit a magnaclean pro 2 they stand off the pipework
Nope fitted loads. Sound as a pound
...Will the standard pipe clips give enough clearance of the wallto fit the valves and BB, or will I need pipework alterations?
Looks like you have to use the gate valves, like on the pumps, either side of the filter. Just 22 clips won’t do. So, you will need to alter your pipe work to come off the wall further.
Looking at the design, just wonder that one could just pull the lever and water goes everywhere. Shouldn't this be child proof!?
Reply to Will Standard Pipe Clips Make Pipes Stand Far Enough Of Wall To Fit Pump Valves? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
