M
MH217
Have recently had a condensing boiler fitted Worcester Greenstar 30si, along with a wireless room stat Siemens RDJ10RF, We have this set at 20 degrees but have noticed that say if it is reading 17degrees when we switch heating on the temp will gradually rise but go to 21 or 21.5 then switch off, the system and house will then start to cool down and the temp on the room stat will go down to around 18 to 18.5 before switching back on. So the temp variations cause the house to be either too cold or too hot.
Is this normal for a room stat or is there a problem. My installer says its fine, but we are not so sure. Also its a nightmare if signal is lost to reprogramme. And a couple of occasions the LCD screen has gone very faint and battery symbol has come on, although I have tested batterys and they are ok but if you take batterys out then put back in, it then ok again. Are there any other wireless stats that are better and more sensitive to temp variations.
Mark
Mark
