- Messages
- 97
Ive got my live from my prg. To my greys
Discuss Wiring s plan from old set up y plan...? in the UK Plumbers Forums area at PlumbersForums.net
Yeah, pair of new valves, il whip the covers offSounds like microswitch not making. Motorised valves new? Have you heard them open?
I haveHave you got 240 on orange when testing between a known neutral/earth, when there’s a demand from programmer and a thermostat?
Sleeve donates a switched live...yes??No greys are perm live
Your live from the prog for heating goes to the room stat and then to the brown on the port valve
So to clarify:I have
Red sleeved brownDepends on colour brown live blue neutral etc
Yeah...So to clarify:
At motorised valves you have a permanent 240 live on grey, 240 on orange and 240 on brown when calling?
This was how it was on y plan...
Yes, sorry, my greys are fed from perm live, which also feeds the prog.No greys are perm live
Hope you guys arnt busy tonight...Time for a rewire and start from scratch bell the existing cables out to see what you’ve got down stairs and adjust in the box to match
So, i think its all right,Are those white wires still connected? Can you post a decent photo of those Wago connectors?
I have my browns to the blue, and red,
Which run back up to the out puts from cylinder stat and room stat..
Il check after my scampi and chipsSo turn the heating on prog should give you 240 to the room stat
Turn the room stat up you should have 240v on the 2 port brown and the 2 port lever should go slack
Correct ?
NB the colours of the cables except from the zone valves could be misleading to say the very least.
I recommend you confirm all the connections
does your boiler need PL and SL ?
Yes 330 does need both
The op is not as dumb as you may thinkI suspect the OP doesn’t understand this
Reply to Wiring s plan from old set up y plan...? in the UK Plumbers Forums area at PlumbersForums.net
