Discuss worcester 24 cdi - after hot water demand noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
greenockboy
sorry, thought I was logged in :smile5:
Hi, just looking for opinion on a tapping noise our boiler has only recently started doing..Only happens just after hot water is turned off, and is loudish tapping noise for maybe 1 minute with time between tapping getting longer till it stops completley. Never happens on CH...
We recently had a gas safe guy chemical flush the system and fit a magneclean fliter.. Not sure if this is related.
Any thoughts on whether it is dangerous or ok to leave or any other advise?
cheers !
Hi, its from inside boiler, sounds like its coming from next to ignition flame, which i'm presuming means is coming from secondray heat exchanger... Boiler is about 13/14 years old I think, was already installed when moved in some time ago.
Could be scaled up. You could try a boiler silencer additive.
Reply to worcester 24 cdi - after hot water demand noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
