Discuss Worcester 24CDi DHW cutting out. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester 24CDi.Central heating works fine and DHW is fine when CH is running.However, during the summer with no CH running,when DHW tap runs,the water heats but after switching off goes to reset and requires resetting before it will switch on again.Is this a sensor problem? Or what.Any ideas gratefully received.
You need the services of a gas safe engy I'm sorry to say
Hi Henry, sorry you need an GS engineer out , we cant give out any boiler info , its against the rules I am afraid .
Sorry bud as town points out we cant give out that sort of advice you need a GRSI to sort it out cheers kop
Reply to Worcester 24CDi DHW cutting out. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Morning Guys, I have a Worcester 230 Combi in a rental property that is going to overheat lockout after a couple of minutes on DHW, no issue when on CH but if DHW is called for when heating is on same fault occurs. System is clean as always had inhibitor so unlikely to be a blocked heat...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for heat, the boiler fires up, modulates, but jumps very quickly (about 30 seconds or so from 40'ish all the way to 70, burner disengages putting it the...
Hello, Looking for someone who can please help solve this problem and fix our boiler. Staffs area. CH seems fine. Boiler can be coaxed into full burn with the fan spinning at full speed, so I think everythings fine on the gas/air/flue/condensate side of things. If there is DHW demand on the...
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring the boiler, the demand light works fine. When the water gets up to temperature every 10 seconds or so, the boiler stops for a fraction of a second...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by the previous owner, they decided to run pipes all along the edge of the garage floor... I do however have one that goes vertically out of the concrete...
