Discuss Worcester 24si 11 - min burner pressure & pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beesley121
Hi guys,
i went to a worcester 24si 11 the other day, neededa new fan as bearing had gone. Replaced it and decided to check burner pressure. Adjusted maximum burner pressure but there no info for the minimum burner pressure as theres a separate adjustment screw on the gas valve for that? Any ideas?
-also, boiler needs a new pcb, the mi state 2 different part numbers depending in wether the it is 'after FD387' or 'before FD387'
any idea what this means?
26.4kw net = 12.1mb
7.9 kw net - 0.9mb
Max rate DWH fga 5.8-6.2%, ratio = 0.002 - 0.010
2mm allen key req for max adjustment and 3mm allen key for max adjustment both at p2 (clockwise to increase, anti to decrease
PCB part number 87483004880 (double check though first)
Cheers
Thanks for the reply mate but just found out this is the older boiler of the 2 versions. Still dont know what the min burner pressure should be on this version though
Yes mate but only gives me the maximum burner pressure and not min
Ha, thats either the wrong link or i want to find an installer even though i am an installer hehe
What a waste of 20 seconds
P.C.B depend on which gas valve you have, 2 or 3 plug. I think the 3 plug has connection on back of gas valve, 2 plug on the front. (Maybe other way round!) It's easier than trying to figure out the manufacturer date. Normally on the non condensing Worcesters the min is about 1.5mb. Worcester will tell you but as long as it stays lit when you pull the lead off the modureg its o.k. The differance of a mb on min isn't overly important IMO.
Reply to Worcester 24si 11 - min burner pressure & pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
