Discuss Worcester 28CDI fluctuations in pressure and leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
I have a Worcester 28CDI and recently I have noticed that the pressure is going from 1 bar cold up to the maximum 4bar within 20 minutes when turning the central heating on. There is also water leaking from the bottom of the boiler. The heating and hot water seem to be functioning fine. I've turned it off before it reaches 4 bar incase something bad happens. When the system is off the pressure drops down to 1bar.
Any ideas what the problem might be and how much to fix it? Hopefully it doesn't mean a new boiler. Thanks.
Register with us and repost your question matey. Should be a fairly easy fix for a gas safe engineer but we cannot suggest diy boiler fixes. Welcome along
Think there are 2 threads running here mate.
Reply to Worcester 28CDI fluctuations in pressure and leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
losing pressure
L
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
