Discuss Worcester boiler needs refilling daily in the Plumbing Jobs | The Job-board area at PlumbersForums.net
proelitegas
Hi just got a customer complaining he is having to fill his boiler
Daily.When central heating is on pressure rise as normal on
Gauge but when heating is off pressure falls and discharge via blow
Off..I'm thinking expansion vessel needs recharging any other thoughts
Would be appreciated..thanx
absolutely worth checking the EV but to me it sounds more like the PRV is letting by as it's happening during the off, ergo cold, period
Any tips on checking the operation of the prv ???
not really a way of checking the operation as such, they're usually set at around 3 - 3 1/2 bar so if it went then the system for whatever reason got fairly high on pressure. The trouble is once they go very often they don't re-seat properly, there may be a bit of grit on the seating or the washer may have perished. Some can be dismantled and cleaned but most techs don't bother they just re-new.
proelitegas .. filling daily with no wet carpets or saggin ceilings usually means exp vessel lost charge and 9/10 prv taken out! As for checking prv I wouldn't recommend it ... In my experience once they've been pasing they rarely sit sealed again! :)
Thanx everyone will check e v and if need be recharge see how
That goes...Thanx again
agree +1
Plus plus 2
I had an ecotec last week that had blown it's internal rubber flow pipe (the merchants told me that they're selling at least 3 adjustable hard pipe replacements every week, apparently it's a design fault) anyway, the over-pressure on this particular boiler was caused by a faulty internal filling loop, in this case there was nothing wrong with the prv or ev, not saying that this is your problem but it maybe worth a quick check
Reply to Worcester boiler needs refilling daily in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hi all, I wonder if someone can help. We have a Worcester MT10 combi boiler that has a fault with the expansion vessel. The landlord is having...
