Discuss Worcester Boiler Shut Itself Down in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
frasere
Hi
I've got a Worcester Bosch 350 Combi boiler which just seems to have shut itself down tonight as if it has no power at all. When I checked it the pressure was pretty low so I topped it up. I'm assuming it shut down due to low pressure but the boiler won't come back on now.
It's done this once before and then randomly come back to life. The guy that came out to fix it didn't have to do anything as it had sprung back into action by the time he got there.
Is there some kind of reset procedure I can follow or does it shut down for a set amount of time when the pressure drops too much? Or is it something else completely different!
I've located the reset button on the top right of the boiler but it doesn't seem to move and I can't press it in.
Thanks for any help or advice
Fraser
The boiler is shutting itself off because of the over heat stat. Get a geas reg engineer back in to run a full check.
Reply to Worcester Boiler Shut Itself Down in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a...
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
