Discuss Worcester Bosch 28i Junior Boiler problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
simonbuk
Having trouble with my Worcester Bosch 28i Junior.
Got up yesterday and the red warning light was flashing, followed the instructions to reset it and got it working again, topped it up with some water too as the pressure was just below 1 bar.
Got up this morning to a cold house, the red light is flashing and the water pressure is pretty much zero.
Whats happened ? Have I lost a load of water ? Can't find any evidence of, just about to start pulling up floor boards but thought I'd ask here first in case i'm missing something.
Regards
Look outside where the 15mm discharge pipe work terminates.
Just put the tip of your finger over the end or just inside to see if it's wet or has been wet.
No sign of any water, might have happened last night when I was out but think I would still be able to see evidence of water marks on the wall.
Before you start ripping up floorboards call a GSR in to check the boiler out.
Reply to Worcester Bosch 28i Junior Boiler problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
