Discuss Worcester Bosch Danesmoor 20/25 Problem in the Oil and Solid Fuel Forum area at PlumbersForums.net
Is there anyone out there who has come across this problem.
Our boiler locked out so pressed the reset button and it seemed that all was fine. Red light went out and fan started etc. About an hour later noticed nothing seemed to be warming up. But motor was still running and no lockout. Called out service guy who replaced photocell. Same result, motor starts no ignition but motor continued to run.
So he replaced control box (Honeywell TF832.3) the replaced box had some heat damage at top right corner. Service man said faulty photocell could have damaged controller.
Tried again, same result. Service man checked ignition unit and replaced. Again he said there was evidence of heat damage.
This time boiler fired and ran, for just over an hour. No lockout but cold pipes. Service man came out again and replaced control box. Boiler fired and ran. This time for just over two hours.
Questions.
1. Why is the boiler not locking out and motor turning off when there is no flame? Honeywell data sheet and common sense suggest that a lock out should occur.
2. Has anyone come across this type of problem before and any suggestions?
Thanks Guys
Reply to Worcester Bosch Danesmoor 20/25 Problem in the Oil and Solid Fuel Forum area at PlumbersForums.net
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
Help Please We have a 2005 Worcester Bosch Oil Heatslave 26/32 that is fitted with the optional timer. Recently we have a problem. To get either...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
Hi Folks I'm wondering anyone here, has any indepth knowledge on the Worcester Heatslave Combi Boiler. This boiler is quite old (2006) but it has...
1K
I have a customers trianco burner that starts from cold ok for a few minutes (say 3minutes) then locks out then will not stay on. Boiler had not...
