Discuss worcester bosch fault codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jacky_boy
got a fault on a worcester bosch heat slave 20/25, the code is 9f flashing on the screen. tried resetting the main one on the boiler, reset on the overheat stat and also on the burner, no avail.
if anyone could point me in the right direction of some fault codes that would be excellent. cant find any in the booklet that came with the boiler.
Cheers lads.
Reply to worcester bosch fault codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Noticed today that the ground looked damp around the outside of our Worcester Bosch Heatslave 25/32 External Boiler. Took the cover off and warm...
2K
Hi I was initially having a Megaflo ( 170 L ) and a Worcester Bosch 30 ( RI System Boiler ) in a loft conversion The guy that was doing the work...
2K
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and...
2K
Hey Folks. I have a Worcester Bosch Greenstar 24i Mk4 system boiler that is locked out. The boiler was working correctly, then the gas supply was...
2K
We have a Worcester system boiler, an unvented HWC and mains water pressure to the house. I paid £420 to fix issues we have with our heating...
Deleted member 120897
