Currently reading:
Worcester bosch junior 24 i
Discuss Worcester bosch junior 24 i in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jitenbulsara
I am needing some help on a 24i regarding internal leaks.About three months ago I re pressurised a 24 i and checked all the rads left the system running.three months later it's dropped below running pressure so tracing 1 bar over three months is lots of investigating.I will put in a leak sealer and see but just wanted advice if anyone has injured an issue with a 24i and internal leakage?.....
You need to be a GSR Engineer to work on the boiler.
As far as leak sealer goes, my advice is to find the leak and fix it, don't put that in.
If its a water leak inside the boiler, Then you still need a GSR Engineer
1 bar over three months will be hard to find, especially if leaks only when system cold, but sheet of paper below boiler might confirm an internal problem.
Sounds like it but to open it up you need to be Gas safe
Jiten, we've already got your details, I'll fire off a note to the admins.
I'm going to close this thread for the time being but as soon as your yellow badge is showing I'll move and reopen it, as well as the others you asked for help on.
Reply to Worcester bosch junior 24 i in the Plumbing Jobs | The Job-board area at PlumbersForums.net
