Discuss Worcester CDI U Codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Kewat66
Hi All,
i have been working on a Worcester 35 CDI. The boiler wasn't getting the heat away and was going up to 99 on the screen and then going into u codes. Nothing in the manual on these but having changed the pump, diverter motor & temp sensor the boiler worked for a week then started playing up again. The new pump had failed so was changed again but the original problem is still happening albeit not as often. Worcester have said to change the board but not sure about this. Does anyone no about these u codes and has anyone had a similar problem?
thanks
kewat66
2 digit display... It goes to U to indicate over 100 degrees... Eg u9 is 109
Hello i have had the same issue before when running hot water, just cleaned out the plate heat exchanger and its been fine since. You do not need a new pcb at ÂŁ200.
Reply to Worcester CDI U Codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the...
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
