Discuss Worcester greenstar 28i junior dripping flow turbine in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the_d_o_t
Hello people
i have a Worcester greenstar 28i jnr where there was a leak coming from the front section (if you was looking stood in front of the boiler) of the flow turbine
I've herd its quite common on this model because they came up with the fantastic solution of covering the diverter with a green rubber johnny to protect from the drips on the next model
i have replaced the ring washer but still drips...... would you say the flow turbine needs replacing or the plastic housing that contains the flow turbine or both!?
any guidance on this one would be appreciated
Thanks Nick
I've had this before. Look at the flow restrictor in the same housing behind the flow turbine.
As Cropps said, the restrictor housing crumbles around the o ring
They're about 3 quid in Plumbs
Just use plenty of grease
Reply to Worcester greenstar 28i junior dripping flow turbine in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
