Was having a look at a Greenstar 28i junior, customer called with no heating or hot water.
I found the red silicon tube was split so repaired that, the boiler still went into lockout (flashing reset and slow flashing blue light - mostly off), the ignition light never comes on, manual says ignition failure.
I checked the gas valve and both solenoids had 35v and the resistances were 177ohm and 393 ohm both within spec.
I didn't have time to check any further and will be going back tomorrow, as it is not a boiler I am very familiar with I thought I would ask here first.
It is a vertical flue which is clear and I cleaned the condense trap.
