Discuss Worcester Greenstar 30CDi - Juddering - Rusty Deposits On Pipe (Pics) in the Central Heating Forum area at PlumbersForums.net
Hi everyone!
My Worcester Greenstar 30CDi Combi boiler started making a rather loud juddering noise two nights ago. I bled all the radiators and releaaed air from the system. Repressurised the system afterwards with the water valve and the noise had stopped... until about the same the next day. The noise started again, although it wasn't as loud. I have turned the boiler off for now and decided to look underneath the boiler to see if I could see anything obvious. I discovered some rusty-coloured deposits forming a stalactite hanging from the leftmost joint. Also deposits around different seams of said joint. I touched the end of the stalactite and a small piece snapped off. It was also a little wet on the end. I have attached images of these deposits.
Is this likely to be the cause of the juddering? The boiler has also been slowly losing pressure. Is this likely to be causing that, too?
Any help is apreciated :)
Thanks,
Phil
No that’s just a washer leaking
Is the boiler making the sound or the radiators
Reply to Worcester Greenstar 30CDi - Juddering - Rusty Deposits On Pipe (Pics) in the Central Heating Forum area at PlumbersForums.net
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
The rusty bit with a hole at the top looks quite old, feels flimsy, and is a single skin 100mm x 400mm. The boiler has a 600mm new pipe rising...
Condensing boiler installed by local Gas Safe plumber in 2014, not combi. Failed a couple of weeks ago with flashing blue light which googling...
4K
I have a 16 year-old Worcester Bosch Greenstar 35 CDi combi boiler, which is recently suffering from intermittent issues with the hot water. I...
3K
